Radiant Heat Exchange Parallel Disks Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Engineering Physics
Radiant heat exchange for two isothermal (constant temperature) parallel flat black disks equation and calculator.
Preview: Radiant heat exchange for two parallel disks same size calculator
The heat flow (q) from the plate is calculated as:
q = 56.69 x 10-9 x VF(1-2) x A12 x (T14 - T24 )
Where 56.69 x 10-9 is the average Stefan-Bolzmann constant, A1is the area of the disk, T1 is the plate 1 temperature and T2 is the disk 2 temperature. The view factor VF(1-2) (also known as radiation shape factor, angle factor, and configuration factor) is defined as:
Length of plate 1 divided by the distance between the plates (L 1 / D) must be greater than 0.2 for this calculation.
r1 = rad1 / D
r2 = rad2 / D
X = 1 + ( (1 + r22 ) / r12)
A1 = Area (W)
D = Spacing (m)
rad1,2 = Radius (m)
T1 = Plate 1 Temperature (K)
T2 = Plate 2 Temperature (K)
VF1-2 = View Factor
q = Radiated Heat Flow (W)
References
Rosenow, W. M., J. P. Hartnett, Y. I. Young, Handbook of Heat Transfer , 3rd Ed., McGraw-Hill Handbooks, New York, 1998. p. 7.3 - 7.19, 7.82.
