Related Resources: fluid flow
Impulse-Momentum Principle For Fluids Formula
The Impulse-Momentum Principle is derived from Newton's 2nd law in vector form which states that the rate of change of linear momentum of a body is directly proportional to the external force applied on the body, and this change takes place always in the direction of the force applied.
The resultant force in a given direction acting on the fluid equals the rate of change of momentum of the fluid.
∑ F = ∑ Q2 ρ2 v2 - ∑ Q1 ρ1 v1
∑ F = the resultant of all external forces acting on the control volume
∑ Q2 ρ2 v2 = the rate of momentum of the fluid flow entering the control volume in the same direction as the force
∑ Q1 ρ1 v1 = the rate of momentum of the fluid flow leaving the control volume in the same direction as the force
Vennard, John K. and Robert L. Street, Elementary Fluid Mechanics, John Wiley & Sons, Inc., 1982.
