Related Resources: fluid flow
Duct Roughness Factors Table
Fluids Engineering Table of Contents
Hydraulic and Pneumatic Engineering
Roughness factors listed in Table 1, are recommended for use with Colebrook Formula.
Duct Type/Material
Absolute Roughness ε, ft
Range
Roughness Category
Drawn tubing (Madison and Elliot 1946)
0.0000015
Smooth 0.0000015
PVC plastic pipe (Swim 1982)
0.00003 to 0.00015
Medium smooth 0.00015
Commercial steel or wrought iron (Moody 1944)
0.00015
Aluminum, round, longitudinal seams, crimped slip joints, 3 ft spacing (Hutchinson 1953)
0.00012 to 0.0002
Galvanized steel, round, longitudinal seams, variable joints (Vanstone, drawband, welded.
Primarily beaded coupling), 4 ft joint spacing (Griggs et al. 1987)
0.00016 to 0.00032
Average 0.0003
Galvanized steel, spiral seams, 10 ft joint spacing (Jones 1979)
0.0002 to 0.0004
Galvanized steel, spiral seam with 1, 2, and 3 ribs, beaded couplings, 12 ft joint spacing
0.00029 to 0.00038
0.0002 to 0.0004
0.00029 to 0.00038
Galvanized steel, rectangular, various type joints (Vanstone, drawband, welded. Beaded
coupling), 4 ft spacinga (Griggs and Khodabakhsh-Sharifabad 1992)
0.00027 to 0.0005
Phenolic duct, aluminum foil on the interior face, sections connected with a four-bolt flange and
cleat joint (Idem and Paruchuri 2018)
5 ft spacing:
0.00049 to 0.00128
10 ft spacing
0.00025 to 0.00098
Wright Friction Chart:
Galvanized steel, round, longitudinal seams, 2.5 ft joint spacing,
0.0005
Flexible duct, nonmetallic and wire, fully extended (Abushakra et al. 2004; Culp 2011)
0.0003 to 0.003
Medium rough 0.003
Galvanized steel, spiral, corrugated,b Beaded slip couplings, 10 ft spacing (Kulkarni et al. 2009)
0.0018 to 0.0030
Fibrous glass duct liner, air side with facing material (Swim 1978)
0.005
Fibrous glass duct liner, air side spray coated (Swim 1978)
0.015
Rough 0.01
Flexible duct, metallic corrugated, fully extended
0.004 to 0.007
Concrete (Moody 1944)
0.001 to 0.01
a Griggs and Khodabakhsh-Sharifabad (1992) showed that ε values for rectangular duct construction combine effects of surface condition, joint spacing, joint type, and duct construction (cross breaks, etc.), and that the ε-value range listed is representative.
b Spiral seam spacing was 4.65 in. with two corrugations between seams. Corrugations were 0.75 in. wide by 0.23 in. high (semicircle).
ASHRAE Handbook of Fundamentals - 2021
