Related Resources: fluid flow
Copper Pipe Flow Friction Loss Size 0.5 to 1.00 inch diameter
Friction Losses to Water Flow in Copper Pipes Size 0.5 to 1.00 inch diameter
See also
Tables are for Copper pipe with a surface roughness of C=130.
Nominal Size, in.
0.5
Type K Tubing
Type L Tubing
Type M Tubing
Dia. 0.527 in.
Velocity, fps
Head Loss
ft/100 ft
Dia. 0.545 in.
Velocity, fps
Head Loss
ft/100 ft
Dia. 0.569 in.
Velocity, fps
Head Loss
ft/100 ft
gpm
0.5
0.74
0.80
0.69
0.68
0.63
0.55
1
1.47
2.89
1.38
2.46
1.26
1.99
1.5
2.21
6.1
2.06
5.2
1.89
4.22
2
2.94
10.4
2.75
8.9
2.52
7.2
2.5
3.68
15.8
3.44
13.4
3.15
10.9
3
4.41
22.1
4.13
18.8
3.79
15.2
3.5
5.15
29.4
4.81
24.9
4.42
20.2
4
5.88
37.6
5.50
31.9
5.05
25.9
Nominal Size, in.
0.75
Type K Tubing
Type L Tubing
Type M Tubing
Dia. 0.745 in.
Velocity, fps
Head Loss
ft/100 ft
Dia. 0.785 in.
Velocity, fps
Head Loss
ft/100 ft
Dia. 0.811 in.
Velocity, fps
Head Loss
ft/100 ft
gpm
1
0.74
0.54
0.66
0.42
0.62
0.36
2
1.47
1.94
1.33
1.50
1.24
1.28
3
2.21
4.1
1.99
3.2
1.86
2.71
4
2.94
7.0
2.65
5.4
2.48
4.6
5
3.68
10.5
3.31
8.2
3.11
7.0
6
4.42
14.8
3.98
11.5
3.73
9.8
7
5.15
19.6
4.64
15.2
4.35
13.0
8
5.89
25.2
5.30
19.5
4.97
16.6
Nominal Size, in.
1
Type K Tubing
Type L Tubing
Type M Tubing
Dia. 0.995 in.
Velocity, fps
Head Loss
ft/100 ft
Dia. 1.025 in.
Velocity, fps
Head Loss
ft/100 ft
Dia. 1.055 in.
Velocity, fps
Head Loss
ft/100 ft
gpm
2
0.83
0.47
0.78
0.41
0.73
0.36
3
1.24
1.00
1.17
0.87
1.10
0.75
4
1.65
1.71
1.56
1.48
1.47
1.28
5
2.06
2.58
1.94
2.23
1.84
1.94
6
2.48
3.6
2.33
3.1
2.20
2.72
7
2.89
4.8
2.72
4.2
2.57
3.6
8
3.30
6.2
3.11
5.3
2.94
4.6
10
4.13
9.3
3.89
8.0
3.67
7.0
11
4.54
11.1
4.28
9.6
4.04
8.3
12
4.95
13.0
4.67
11.3
4.40
9.8
13
5.36
15.1
5.05
13.1
4.77
11.4
14
5.78
17.3
5.44
15.0
5.14
13.0
Source
