Vertical Storage Tank Selection Excel Spreadsheet Calculator
Download: Vertical Storage Tank Selection Excel Spreadsheet Calculator
The excel workbook provides selection of vertical storage tank diameters based on classification of liquid stored and the pressure rating of the tank. It also provides a wind stability chart as a function of diameter and height of the tank. Fixed Roof Tanks with Internal Floating Roof:
A fixed roof tank may be provided with an internal floating roof to reduce the vapour losses and air pollution. It is recommended that their use is limited to tanks with a maximum diameter of 39 m. Design of fixed roof tanks with an internal floating roof shall be in accordance with Annex H of API STD 650.
Abbreviations:
HPCRT: High-Pressure Cone Roof Tank
LPCRT: Low-Pressure Cone Roof Tank
NPCRT: Non-Pressure Cone Roof Tank
HPDRT: High-Pressure Dome Roof Tank
LPDRT: Low-Pressure Dome Roof Tank
NPDRT: Non-Pressure Dome Roof Tank
OTFR: Open-top Tank with Floating Roof
Ankur Srivastava
Chemical Engineer
