UPS Requirements Calculator Spreadsheet
Electronics, Instrumentation & Electrical Database
Uninterrupted Power Supply (UPS) Requirements Calculator Spreadsheet
Download: Uninterrupted Power Supply (UPS) Requirements Calculator Spreadsheet
- Inverter / UPS Details
Total Load
Total Starting Load
Inverter efficiency
Size of Inverter / UPS - Inverter / UPS Battery Details:
Battery Voltage Volts DC
Inverter / UPS Back Up Time Hour
Loose Connection/Wire Loss Factor:
Battery Efficiency
Battery Aging:
Depth of Discharge:(DOD)
Battery Operating Temp: C°
Current drain from battery Amp
Normal storage capacity of Battery Amp.Hr
Average Load Amp.Hr
Size of Battery Amp.hr
- Battery Bank Connection Detail :
If You are Select Battery Volt Volts DC
If You are Select Battery Size Amp.Hr
Batteries connection for Battery Bank Series-Parallel
Selection of Batteries Connection:
Selection of Each Battery Voltage
Number of String for Battery Bank
Total Amp.Hr of Each String Amp.Hr
Total No of Battery in Each String
Total Battery Bank Amp.Hr Amp.Hr
Total Nos of Batteries in Battery Bank Nos
- Results:
Size of Battery
- Determine the general need for an UPS.
- Determine the purpose of the UPS.
- Determine the power requirements.
- Select the type of UPS.
- Determine if the safety of the selected UPS is acceptable.
- Determine if the availability of the selected UPS is acceptable.
- Determine if the selected UPS is maintainable.
- Determine if the selected UPS is affordable.
