Metal Fatigue Engineering Analysis Excel Spreadsheet Calculator
Vibration Design and Engineering
Beam Deflection and Stress Formulas and Calculators
Note: Accessing this resource requires an active Premium Annual Membership with Engineers Edge
Download: Metal Fatigue Engineering Analysis Excel Spreadsheet Calculator
Definitions
1. Components are designed to withstand: direct forces, moments and torsion.
2. These loads may be applied gradually, suddenly, or repeatedly.
3. A static stress analysis leads to a dynamic stress evaluation.
4. Stress is Force per unit Area, σ = F / A (psi or Pa)
5. Strain is extension divided by original Length, e = x / L (number)
6. Strength is the Stress of a tested material at failure, S = Fmax / A (psi or Pa)
Calculations:
- Principal Stresses
- Strength and Fatigue Failure Theories
- Maximum allowable static direct stress.
- Distortion energy
- S-N Diagram and Curves
- Notch Theory and Analysis
- Notches and Stress Concentration in Fatigue Cyclic Loading
- Catilever Bracket eith fully reveresed bending
- Fatigue Crack Growth Analysis Review | Engineers Edge | www.engineersedge.com
- Fatigue - Strength ( Mechanics ) of Materials - Engineers Edge
- Fatigue and Machine Design Excel Spreadsheet Calculator | Engineers Edge | www.engineersedge.com
- Local Stress-Strain Fatigue Method ( ε-N ) | Engineers Edge | www.engineersedge.com
- Fatigue Design Based on S-N Data | Engineers Edge | www.engineersedge.com
- Miner's Rule Linear Damage Rule | Engineers Edge | www.engineersedge.com
- Ball Bearings Fatigue Life Calculations and Load Ratings Calculation - Engineers Edge
- Fatigue Testing Gear Materials | Engineers Edge | www.engineersedge.com
