Bolt Threads, Grade, Bolt Strength, Excel Spreadsheet Calculator
Fastener, Thread, Bolt Design and Engineering
Spreadsheet Calculator Calculated per the AISC Ninth Edition
Download: Bolt Threads, Grade, Bolt Strength, Excel Spreadsheet Calculator
Preview
Reference: AISC 9th Edition Part 4 - 3 tension on gross area | ||||
Section J - 3, page 5 - 72 and some common sense | ||||
American Institute of Steel Construction (AISC) |
A36 can be purchased at the hardware store as allthread rod. | ||||||||
A354 Grade BD is usually specified as interchangeable with A490 bolts. A354 Gr. BD is often | ||||||||
furnished as a high-strength anchor bolt and is also used in high temperature conditions, like | ||||||||
your car engine's head bolts. | ||||||||
Comparison of Published and Calculated Threaded Areas | |||
Values in the AISC Ninth Edition, First Printing (7/89) vary from | |||
the formula 0.7854*(D -1.3 /n)² for the root area AK. The | |||
difference between the first and second AISC printings is shown | |||
below and in the graph. ICE calculations equal the revised | |||
AISC values. |
Epifoam sleeves, pipes, and plastic pipes are used to prevent concrete bond with | |||
the bolt. This allows bolt stretch during impact events. The bolt can be pretensioned | |||
with the hit wrench or a large impact hammer. Calculate the turn of the nut versus | |||
the length of the bolt between the nuts. | |||
