Engineers Edge
Temperature Controlled Chamber Review
Environmental Chamber Menu
Temperature Controlled Chambers are used for many applications including: testing, research and development, assembly , calibration, storage, precision measurement applications, thermal cycle testing, and polymer, paint, or adhesive curing. These applications are found in a diverse number of industries such as; electronics, petrochemical, pharmaceutical, plastics, aerospace, automotive, packaging, scientific and biomedical.
Temperature controlled environmental chambers are also equipped with a variety of controls, these include: humidity, pressure, vibration, air or water cooled or heated, indoor or outdoor installation, ramp and/or soak operations, custom air handling systems and shock testing apparatus. Temperature controlled chambers are specified by controlled temperature range, rate of temperature change, height, width and depth, sensors and controller capability.
Courtesy:
Scientific Climate Systems, Inc.
www.engineersedge.com
Advertising | Contact
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
