Engineers Edge
Environmental Test and Manufacturing Chambers Review
Environmental Chamber Menu
Environmental test chambers are used within engineering, manufacturing, and research for various testing such as design verification of prototypes, process research, production testing, production curing of materials, product verification, stress testing for thermal, humidity, and failure analysis.  Environmental test chambers verify the reliability of parts and assemblies. particularly electronic assemblies and populated printed circuit boards.
Environmental test chambers are designed and employed to simulate any type of environmental condition or combinations of environmental conditions such as:
  • Temperature
  • altitude
  • Humidity
  • Salt fog
  • Solar
  • Radiation
  • Wind and Rain
  • Dust
  • Complex Chemical Exposure
  • EMC environments
  • Fungus exposure
  • Electromagnetic testing
  • Snow and icing
  • Corrosion testing
  • etc.
Environmental test chambers are manufactured at virtually any size required, from a few square inches up to and including an entire building. Temperatures may be achieved from -300 degrees F to in excess of +1100 degrees F.  Humidity from 10% to 100%.  Environmental vacuum chambers routinely achieve vacuum levels of 10-7 Torr.
www.engineersedge.com
Advertising | Contact
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
