Thread: Dispense Label Only When "Pass" signal is received from Hipot Tester
    Sep 2022
    I am trying to improve our Hipot testing process. Specifically, I want a label dispenser that I can hookup the output signal of the Hipot tester to so that it outputs 1 and only 1 label when a "pass" signal is received and no labels if any other signal is received or no signal is received. Does anyone know of a good device that can do this?
    Thanks!
    2,616
    Your Hipot testing equipment is where you start. Look to see if the manufacturer offers a addon that addresses your need.
    If not, consider the outputs available on the tester or equipment you use and identify potential read and print options on the market.
    The Hipot equipment manufacturer would be my first source of info. Knowing the 'pass' signal output type would help tremendously.
    Can you provide manufacturer info on your Hipot tester? If so I should be able to tell you your options for output signalling.
