Hello, anyone using design calculator and parameters.
Is it assumed oil flow feed goes from inner diameter to outer diameter of bearing?
The existing system I am troubleshooting has lubricant flow pumped from outer to inner diameters, do the taper values reverse ID/OD?
Or is it typical to have larger gap on ID? Seems backwards for my application.
Have a nice day!
