Thread: Basic dim's interpretation
    New Member
    Dec 2023
    Hello and thank you in advance for looking at this drawing (attached).
    I was trying to interpret the basic dim's added to the dwg.
    +10, +1 and -1
    There is no callout other than in the notes regarding
    concentricity.
    I did not create this, nor would I place a surface finish on a
    hidden line (omg).
    Thank you,
    Lorrie
    Attached Files Attached Files
    It's not clear what the box + # is meant to indicate. There is a size and taper indicated ((5 deg.) + the dia. 2.265. Dimensioning to a hidden line is basic drafting no-no.
    Best advice is to contact the engineering drawing creator and ask for a clarification.
    Senior Engineer
    Jun 2022
    30
    I have no idea what the boxes mean, especially since the dimensions already have a max/min format.
    Also, the geometry is over-defined. (A basic error in my opinion.) You have a taper with diameter callouts at each end, as well as a specified angle. The designer should eliminate one of them, or at least make one of them REFERENCE.
    New Member
    Dec 2023
    The larger dia. is a reference dimension.
    Thank you for your comments, I was having trouble interpreting myself.
    New Member
    Dec 2023
    Yeah lot's of errors, not my drawing but I will fix the mistakes.
    Thank you for looking at it!
