Thread: Scissor Lift Formula
    Jan 2023
    I work in automation in the theatre industry and I recently set myself the task of creating a scissor lift/ table from scratch, Iím hoping it will lift 60KG about 500mm.
    Iím struggling to find the correct formulas for working out the force needed to active the scissor lift at different points, e.g the bottom middle or top. Iím hoping someone could point me in the correct direction, please.
    I have found the formula:
    F=(W+WA/2) / Tan (A)
    Where as:
    W = Weight of load
    WA = Weight of arm
    A= Angles of arms to the ground
    However I do not understand where the force calculated should be applied on the scissor lift arm?
    Additionally, I have found the formula:
    The sum of the movement of A = FA X (L/2 x Cos Alpha) - ( F x (L X Cos Alpha)
    Where as:
    FA = Force on actuator
    L= length of leaver
    Alpha = angle of leaver.
    I believe this formula gives me the force on an actuator vertical to a leaver, unfortunately I donít know how to change this so the actuator doesnít have to be vertical.
    I would greatly appreciate any help in finding the correct formulas.
    Iím enjoying learning about this new subject and would love to know what books or reference material you would recommend for future projects.
    I appreciate you taking the time to read this, any guidance would be greatly appreciated.
    2,593
    The formulas are dependent on the configuration of the scissor jack. The resultant loading is determined by statics analysis and each jacj configuration is different.
    There are two configurations with formulas on Engineers Edge here.
    https://www.engineersedge.com/mechan...issor-lift.htm
    If you need a different configuration then you will need modeling software or knowledge of statics.
    Other resources:
    Scissor Lift Design and Analysis Equations
