Thread: Tolerance to centerline allows negative
    Mar 2018
    Rancho Cordova, CA
    Hi, All. Long time reader, first time poster.
    I have a round part with a precision hole along the center axis. The OD has no real functional role but the ID is very important, so datum A is defined by its axis.
    There is a tapped hole in the OD going towards (perpendicular to) the axis. The the thread depth and pilot depth are dimensioned from the axis. For reasons I won't bother explaining, an allowable distance for the pilot hole is .013" short of the axis to .007" past the axis. Can I state .003 ±.010 with a scale appropriate enough to show which direction the nominal .003 is?
    If this isn't legal, how could one define this tolerance zone? Reminder; The OD is loose in size and runout, so calling a depth from entrance won't work without unnecessarily tightening up the entrance surface (OD).
    Screenshot attached.
    216
    You have specified the functional dimension that you want. Looks fine to me.
    Mar 2018
    Rancho Cordova, CA
    Thanks, Hudson. I agree, but our checker does not. Thanks for your opinion.
