The shaft supports you're using are not designed for a thrust load. In fact I don't think their surfaces supporting your thrust bearing are even truly perpendicular to the shaft. Plus they are gripping a very thin area of the extrusion which under load will just deform outward. You say this thing is supposed to support 200 lbs but your picture is unclear, or incomplete. Either way a more thorough understanding is required.
