Thread: Fixed End Connection Design for Purlin System
    Tay
    Dear All,
    Would need yours help as i am working with a roof support design with purlin system. Below is the info:
    C-Lipped Purlin Size = 150(h) x 50(w) x 15(lip) x 1.6mm Thick
    Span of the Purlin = 7 meters
    Spacing between Purlin = 1 meter
    Dead Load = 0.33kpa
    Live Load = 0.75 kpa
    Wind Load = 0.50 kpa
    Connection type: Fixed End with 1 row of sag rod at midspan
    Do anyone can do the design calculation?
    Thanks
    2,624
    Well, EE has a little information here --> http://www.engineersedge.com/civil_e...cture_9898.htm
    First, I would check local building construction codes. Often, they will provided pre-engineered solutions guidelines for roofs and associated structures.
    This may be simpler than you think (applying code)..
