Thread: Controlling low air pressure
    Sep 2018
    I am looking for a device to control low air pressure, open at 2.0 psi, close at 3.5 psi. Any such device?
    Pressure Switch/Sensor - Look at well pump type pressure switch companies and inquire about your on/off pressure range.
    May 2015
    216
    You might use two valves in series. The first would open a 2psi and the second close at 3.5 psi. You could also combine an electrical with a mechanical valve to handle separate conditions.
