Results 1 to 9 of 9
Thread: external pressure vessel calculations
    Jan 2012
    knoxville
    4
    need an equation for (external) crushing pressure of pipe
    Hi Duddy,
    Load x area = failure if only we knew material, diameter, thickness, length, load, point or distributed, ad infinitum. {sigh} Really?
    If you can you tell me the length of this piece of string I will give you the answer and a thousand dollars cash. No, make the ten thousand.
    Jan 2012
    knoxville
    4
    I simply need the equation.... not have it solved for me.
    There are conflicting view points
    The tube is machined to its size not a pipe or tube in the conventional sense (quite different properties than seamed of seamless)
    the operating external pressure is 20,000 psi @350 deg.
    material is nitronic-50 ss
    The name is buddy not duddy
    Pressure Vessel External Pressure Calculations
    Be aware that the equations and very general in nature -
    Jan 2012
    knoxville
    4
    WOW what a acute grasp of the obvious thanks I will try somewhere else
    Info in this thread will get you started...
    http://www.engineersedge.com/wwwboard/posts/4251.html
    I think he has snagged his bag of candy and gone, Bob.
    Jan 2012
    knoxville
    4
    I say again I just need a calculation not have it solved for me
    If you can't help, don't waste my time and yours.
    ---Deleted Comment--- -Admin
    see ya
    Ten days in the brig... Admin
    Last edited by administrator; 01-20-2012 at 07:28 AM. Reason: Being unprofessional
    Quote Originally Posted by buddy View Post
    see ya
    You have been helped. Read the thread again....
