Thread: Steam Turbine Vacuum system.
    emkelgudsanov
    Post Steam Turbine Vacuum system.
    Hello, Newbie here, i have a question about Steam Turbine Vacuum system.
    This is our vacuum interlocks
    • Jet Water Pump press : 5 - 6 bar
    • Vacuum Normal : (-0.86) - (-0.91) bar
    • Vacuum alarm water pump : <-0.75 bar
    • Turbin trip : -0.61 bar
    What might make the vacuum system not work normally and cause a turbine trip? Thx before
    Electric motor defective....
    216
    Let us assume you are referring to a ejector style pump, ( like these Attachment 2025 )
    It is important to remember that pressure does not equal velocity. So the jet pressure reading can be at normal levels even though there is blockage or erosion of the nozzle.
    emkelgudsanov
    Thx for your answer sir.
