Thread: Steam Energy Flow
    Feb 2017
    Steam Energy Flow
    I need to calculate the energy flow down a steam line. I have the mass flow, gauge pressure and temperature of the steam and would like an equation/formula to put into the SCADA/DCS to work out the Energy flow in the line. There is a variable amount of superheat in the steam so I need to compensate with the temperature. Has anyone got a simple formula to calculate it dynamically?
    The gauge pressure ranges from between 3 and 5 barg and the temperature between 180 and 220°C, normal operation conditions 3.5 barg and 205°C.
    Thanks in advance
    May 2015
    216
    Find something called a Mollier chart for steam.
    Feb 2017
    Thanks Hudson. Unfortunately I haven't got the facility to look up a value in a table or chart. I was after the equation that would produce the curve on the chart to enter in the scada for the calculation. I thought there might be a rough mathematical relationship between the variables to enable a viable energy figure to be worked out, especially since I'm only looking at a narrow operation band, but it is looking like it is too complex to work out
    Aug 2012
    UK
    433
    The "simple" equation is h=u+Pv.
    h=Enthalpy (kJ/kg)
    u=internal energy
    P=pressure
    v= Volume
    You'll be screaming out for chart or a big old MathCAD lesson after you're done trying to have fun with this.
    PS
    I hated Thermodynamics. Still do, to a degree.
