Thread: Hydraulic cylinder question
    bilalkhana556
    Hello !
    I am working on a project with to antagonistic hydraulic cylinders. They both have two brackets with two screws each, i.e 8 screws in total.
    how do I calculate the load(forces) that will affect the screws once the cylinders are moving?
    I also added an image to make it easier for you guys to understand.
    Are you saying you don't know how to calculate the force generated by a hydraulic cylinder? Or is your question something else?
    Assuming there are four "all-thread" studs located equally-ish spaced the shear force applied to each stud would be (Force applied by cylinder max)/4 in a perfect world.
    For hydraulic cylinder force calculations, see:
    http://www.engineersedge.com/hydraul...orce_10105.htm
    For the single and double shear force/stress applied to each stud see:
    http://www.engineersedge.com/materia...hear_calcs.htm
    The "all-thread" studs are not meant for large shear loading, you should consider a bolt or stud where the loading is applied to a bolt grip area.
    "all-thread" studs are best used for compression and tension loading
