Thread: Target datums ?
    Steve
    Target datums ?
    Hi Im in areospace I wondering is there a tolerance for target datums .
    Welcome to Engineers Edge Steve!
    Yes, technically all features and dimensions have a mechanical tolerance... If the datum target is located via Basic or a Theorectically Exact Dimension (TED) , then the datum target is located to gauge makers tolerance.
    A datum target can also be located with a limit tolerance (+/-).
