Hi, welcome to the forum.
How constrained are you for the inner wall height? If you can sneak say 2" it would not be visibly obvious but you could then use 2 x 6 instead. It means trimming the drywall though.
Spacing them closer together than the conventional 24-OC, would give you greater overall-stiffness if you are worried about sag over time.
