There will not be a simple chart vs wall support reference webpage.. not that simple.
First, determine the beam or structural section you think might work..
https://www.engineersedge.com/struct...pes_menu.shtml
Determine the Area moment of Inertia
https://www.engineersedge.com/standa...properties.htm
Then determine the Yield strength of the material used in the structural shape
https://www.engineersedge.com/materi...d_strength.htm
https://www.engineersedge.com/manufa...s_strength.htm
Determine the desired Factor of Safety (FOS) relative to the yield strength - I recommend 1.5 or so..
https://www.engineersedge.com/analys...ety-review.htm
Figure out the loading configuration then select the calculator that best fits.
Calculate the Deflection, stress and so on and compare to the structural shape specifications and FOS.
Repeat until you're satisfied you have the right structural support member.
