Thread: fastener torque to axial force
    Mar 2016
    Confused fastener torque to axial force
    I am designing an temporary 6061 t6 aluminum locking ring that will fit inside a piece of pipe.
    The ring will be drilled and tapped for radial set screws grade 5 material 1.5" -6 threads.
    The set screws will be tightened radially into the inside diameter of the pipe thereby locking the ring in place temporarily.
    I intend to use 150 ft-lbs torque on the set screws. How can I calculate the axial force of each screw on the pipe ID due to the torque applied to this set screw.
    Mar 2016
    I tried that and got like 6500 lbf.
    > It doesn't take in consideration of the different materials.??
    Quote Originally Posted by straycatboat View Post
    That is the approximate axial force applied by torque regardless of material. The only consideration is friction.
