Thread: Roughness Rt Rzmax
    Oct 2015
    Roughness Rt Rzmax
    Good morning everyone,
    First time I post on this forum, I hope section is right and question is good
    I've to dimension surface roughness and I've just got this reccomandation from supplier:
    (Rt n, Rzmax 2.5n)
    My point is: since Rt is maximum peak-valley height in evaluation length, it should be greater or equal then Rzmax (calculate on sampling length). Also assuming 16% rule for Rt, Rzmax should be at most 1.16n.
    Are there other points to be considered in comparing these two roughness parameters?
    Thanks for supporting,
    2,621
    Quote Originally Posted by cammarasana123 View Post
    (Rt n, Rzmax 2.5n)
    Yes, assuming ISO 4287 - Rt is the Total height of the roughness profile (peak to peak) and Rz is the maximum height of the roughness profile from the mean.
    I suspect that your supplier simply got Rt and Rz reversed..
    Going forward - the surface roughness requirements should be specified first by functional requirements and secondly if the functional requirements are not critical then specified by the target manufacturing process (economics does matter)..
    For reference, see:
    Surface Roughness Conversion
    Oct 2015
    Re
    For reference, see:
    many thanks for supporting !!
    Simone
