If you want to transmit any torque (rotational capacity) I would recommend some other connection (such as a drilled hole through the pipe). As you tighten the U-bolt the pipe will just deform. Even if you are able to get it tight enough to work the first time it won't continue. Once it slips the first time its capacity is greatly diminished.
