Thread: Statics Help
    Senior Engineer
    May 2012
    33
    Statics Help
    This is not homework. I am not a student. I am not a PE. No matter what I will be getting this looked at by a structural engineer.
    I am merely curious for my own ammusement if I am doing this correctly.
    I am trying to determine the resulting loads on Points A and C. I have an offset load attached at point B and supported by points A and C.
    Although I think all the information necessary to solve is here, I'm sure my sketch will need clarification... Green is what is given, Yellow is what I got for a solution.
    Offset load platform calculations.xlsx
    THanks for your help!
    May 2015
    Hello, I hope you are well.
    What type of support are A and B?
    You have to add in your equation the moment applied in B.
