The lifting speed and load will be defined by you. How fast do you want to lift the maximum load at motor maximum speed? Work back from there using the pitch of the lifting lead screw and any gearbox or drive belt ratios. Select a motor with that speed range.
For sizing the motor, calculate the max Horse Power required with the above ratios in mind.
