Thread: Referencing .STEP file as Basic Geometry
    Jan 2015
    I have searched in the Y14.5-2009 standard and online and have not been able to find an answer to this question. Is there a way to reference a step file as basic geometry to apply a profile of a surface tolerance?
    The main purpose is to define a tolerance zone for surfaces with compound curves and other shapes which are not straightforward to dimension. I would expect that these parts would be inspected with a cmm, but could also be inspected (very tediously) using manual means. I would use datums to orient the step file geometry.
    All of my searches point me to adding GD&T callouts to step files, which is not what I'm trying to do.
    Is there an accepted means for referencing step files through gd&t?
    Thanks,
    Mike
    May 2011
    Michigan
    78
    Check out paragraph 8.2 of the Y14.5 standard. In the middle it says that "a digital data file or an appropriate view on a drawing shall define the true profile." Most of us are used to having the true profile be displayed/dimensioned on the view itself, but it does allow for a digital file.
    They don't say exactly how to communicate such a thing, but I imagine it would be via a note referencing the CAD file or whatever.
    Maybe I'm just rehashing the other stuff you saw; you can follow-up with more questions if I'm off-base..
    Typical notes on an engineering drawing referencing the 3D/2D cad Model.
    1. Use 3D CAD Model as Control Master for Shape Reference.
    2. This is a Limited Dimension Drawing, Unless Otherwise Specified, Feature Geometries Are Governed By The Electronic Database. Tolerance of Electronics Data Base Features Shall be +/- .XXX.
    3. Untoleranced Features are Defined in the Digital Database CAD File # XXXXXX
