Thread: Size of torque wrench
    Oct 2014
    In my design I have a 220 ksi bolt with hex captive head place inside a counter bore hole of size 1" dia and 3.5" deep.
    The torque that i need to apply is 1250 inch pounds.
    What should be the hex head size that i need to provide. Is there any torque wrench tool available with <1" OD?
    Jan 2014
    58
    1250 lb-in is 104 lb-ft, which is well within the range of any 1/2 inch drive socket wrench. What is the bolt (head) size? Different toolmakers have different standards, so sockets ODs vary. Snap-On has some of the best and thinnest wall sockets available. Or perhaps use a hex socket head cap screw and torque it with a hex key.
    Timelord
    Yes. 50-250 inches lbs. Which is 1/4 drive size. Uses small fastners
