Not so much that you need a valve but a "Vapor-Liquid Separator".
I do not really know if this is the right place to post this message ... if it's not then I'm sorry
I am looking for a valve that allows the flow of liquid but prevent air escaping out form let's say a sealed container ...
Is there such a thing?
Actually It will not work for what i need ...
I have a container that has air pressure in it, now I want to insert water into the container without losing the air pressure inside
that's why I said "Valve" ...
Will give you information after getting some info. regarding the same. This is a great message about the situation.
It's like Kelly said - any valve should be fine. Just measure it up and find something that fits and you're good to go. Or do you have any tricks up your sleeve?
