How is the load being applied?
Hi All,
I want to find the deflection in steel plate, 1.2 mm thickk and 600mm(breadth) by 1000mm Length clamped on all edges. What formula would be useful? Thanks
Thanks its is distributed load
Also, see:
Flat Plate Deflections Calculator
I am working on a water tower job and I am in need of some assistance. I would like to verify if the landing plate is strong enough. It is a 1/4 inch thick plate spanning 36". When I do the math I come up with .81 deflection. I do not think this is correct. Please help. Please dont tell me to use the calculators Id like to do it long hand.
If you post a screenshot/photo of your hand calcs it'll be a lot easier to spot where numbers aren't being crunched.
Could you not answer your own question by at least just comparing your result to that of the online calculator?
Hi, where is the online calculator?
