Thread: Beam Question
    Mar 2014
    Question Beam Question
    Hello. I need to build a structure to hold a 2000 lb centered load. It will be 11 ft high with a span of 24 feet. I am thinking two wooden columns and a wooden beam across. What size beams do I need to use? Thanks.
    Mar 2014
    Thanks for these links, but I still need help sizing the wood beam. I am not familiar with the different sizes and types and their respective properties.
    So, using a 4 x 10 with the load applied at a single point and parallel to the 9.75" length, here's what I got.
    Lots of deflection and stress (too much) I would change the span distance closer, stronger material or re-evaluate your requirements.
    Why wood?
    I used the following webpages:
    http://www.engineersedge.com/lumber.htm
    http://www.engineersedge.com/calcula...are_case_6.htm
    http://www.engineersedge.com/beam_be...flection_2.htm
