You will have to register or login (See top or bottom of page) before you can post a message or view images: click the appropriate link to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
REGISTRATION Problems or questions see: Engineers Edge Forums Help & READ ME
What would happen to the accuracy of a float gauge if the fluid it is measuring is heated and why?
Ask your teacher.
Originally Posted by maxmac97 What would happen to the accuracy of a float gauge if the fluid it is measuring is heated and why? If this is homework - the forum rules don't allow this type of question and you should seek out your approved source. If this is a legitimate question an non-temperature compensated float gauge would read a higher level due to the fluid expansion.
Forum Rules
