Results 1 to 6 of 6
Thread: mN Radial Measurement
    Feb 2014
    9
    We have a component shaped like an ‘open helical spring’ for which radial force characteristics are required. The diameter at which we would like to measure force is 0.271”(6.9 mm) although the spring itself expands to 0.375” O.D. (9.4 mm) in its free/ unconstrained state. We think the force the spring exerts would be ~ 100 mN at the target diameter. Our hope is to measure this within a ± 20 mN error. Also note the component is 1” long. The profile and the low force range are currently proving to be challenges, any ideas?
    2,619
    Quote Originally Posted by parisp3 View Post
    To manufacture, measure, analyze?
    Feb 2014
    9
    Measurement has been the issue. One approach using fixtures with semi-circular channels machined and a load cell at one end does not give us the resolution we need. Perhaps there is a displacement technique or a better direct force measurement alternative to a standard strain gauge load cell??
    Senior Engineer
    Jan 2014
    58
    Are you looking to measure a quantity of parts for statistical or inspection purposes or are you just trying to verify your calculations?
    Additionally, I would think that using semicircular channels would introduce a static friction error which my gut tells me would be high and difficult to characterize. After all, a strain gauge load cell implies some displacement.
    Banned
    Jan 2020
    I have the same question as yours, could anyone help me ?
    Banned
    Jan 2020
    To measure the force as you have depicted in the attached image at that very low magnitude, you need a scale with very high sensitivity and precision. You could build a weighing scale. I would suggest building the scale such that the length of the spring is well distributed on a measurement platform. Then you can attach a strain gauge to that platform such that when the platform is deformed, the strain gauge is deformed. The platform should be a material soft enough to transmit the force to the strain gauge and hard enough not to cut or break. Also, you can attach multiple strain gauges to the platform to increase the accuracy and precision of the system.
