Thread: Delta T Cooling time
    Jonathan Finlay
    Hi All,
    I am trying to work out how long it would take hydraulic oil to cool down using a Air cooled heat exchanger.
    The info is as follows:
    ambient temperature: 42 degrees celsius
    inlet oil temperature: 140 degrees celsius
    outlet oil temperature: 50 degrees celsius
    oil flow rate: 48 litres/min
    tank size : 220 litres
    surface area: 2 m²
    air flow: 10 m³/sec
    any help will be appreciated
    thanks
    2,619
    Welcome to EE!
    The following document does a real good job discussing the basics of designing a heat exchanger.
    Heat Exchanger Design.pdf
