Thread: Vacuum Chambers
    Nov 2013
    Vacuum Chambers
    Hi guys,
    I read somewhere that the three most important factors to consider when designing a vacuum chamber are:
    Modulus of rigidity
    Elastic limit
    Rupture limit
    My question is, why? Don't these measure if we have the eactly opposite scenario to a vacuum i.e. incredibly high pressures? We should be caring about compression? No? I'm very confused.
    2,619
    Quote Originally Posted by Atomic_Sheep View Post
    Hi guys,
    Modulus of rigidity
    Elastic limit
    Rupture limit
    How about:
    Material Outgasing
    Vacuum pump(s) selection
    Controls
    Costs.
    Nov 2013
    I'm referring to the design of the chamber only.
    2,619
    OK, what is the pressure difference between the inside and outside of the chamber? Atmosphere = 14.7 psi...
    I read somewhere that the moon was made of green cheese.
    Why?
    Did you question your source?
