We are making a lifting table with double (vertical) scissors
But we have some questions about it :
1) Should we use one or two hydraulic cylinders what are the benefits of one and what are the benefits of two cylinders
2) Do we need to do something special to place the hydraulic cylinder. Should it be placed under a specific angle?
Thanks in advance.
Welcome to EE!
I would design using the least number of hydraulic actuators. For a safety lock, you could use a manually inserted shear pin to hold elevation lock.
To determine loads and hydraulic jack angles see the following for scissor lift equations and online calculators.:
https://www.engineersedge.com/mechan...issor-lift.htm
https://www.engineersedge.com/calcul...tom-loaded.htm
https://www.engineersedge.com/calcul...ter-loaded.htm
