Thread: Trying to verify yield stress calculations for bending a pipe
    Tommy Boy
    Hi All,
    I wanted to calcuate the maximum force I can place on a given iron pipe 2 ft away from a fixed end before it yields to plastic deformation and takes on a permanent set. I have enclosed 3 equations.
    The first equation shows how to calculate the moment of inertia of a pipe.
    Ip=pie*(Dout^4-Dinner^4)/64
    Dout = outer diameter
    Dinner=inner diameter
    The second formula shows deflection I would get for a given load.
    Deflection=F*L^3/3*E*Ip
    F=Force
    L=Lenght of pipe
    E=Modulus of Elasticity of Iron
    Ip=Moment of Inertia of pipe
    The third formula I am trying to use to calculate the maximum stress for a given force over a given length of pipe.
    Yield Stress Max for given load=((F*L)*h/2)/Ip
    F=Force
    L=Lenght of pipe
    h=height of pipe or outside diameter of pipe
    I am hoping that this 3rd formula is correct and that as long as the calculated value is less than the yield stress of a given pipe material i wouldn't deform the pipe.
    Any thoughts would be helpful.
    Thanks,
    Tom
    Yes, I think...
    See:
    Moment of Inertia
    http://www.engineersedge.com/materia...gyration-3.htm
    Cantilever, single load at end
    http://www.engineersedge.com/beam_be...m_bending9.htm
    Cantilever, uniform load
    and
    http://www.engineersedge.com/beam_be...m_bending8.htm
    [quote]Yield Stress Max for given load=((F*L)*h/2)/Ip[\quote]
    I would just call this applied stress, as yield is a condition where the applied stress exceeds the yield stress and deformaton occurs.
    To get the yield stress of the material you need to find a stress-strain curve or the material specifications of the pipe.
    Quote Originally Posted by Tommy Boy View Post
    Hi All,
    I wanted to calcuate the maximum force I can place on a given iron pipe.................
    ................Any thoughts would be helpful.
    Thanks,
    Tom
    Hi Tom,
    Remember that results from any formula regarding strength of materials are theoretical. So along came the safety factor...
