“Do it yourself” post processing?
I am developing a complicated product where most of the parts have to be 3D printed. The production version will mostly be made from PA12 printed using MJF as it is a bit stronger than PA12 SLS. These parts will be polished as part of the prototyping/production process. One part of the product is under a lot of bending stress and needs to be very stiff and strong. I have been prototyping this part on my Ultimaker S5 using PA12-CF. I have managed to push this beyond normal suggested guidelines and have been able to print it with a 0.15mm layer height and a 0.40mm print core. The problem is that it has a very rough finish, as is typical any time you add carbon fiber to a material. I have been thinking of trying to smooth this out during the prototyping / beta testing phase of the project using a rock tumbler and some type of polishing material such as ceramic. Before I invest in the equipment to try this, I wonder if anyone has tried smoothing 3D FDM prints using a rock tumbler. When the product goes into production, this will probably be made by SLS with PA12-CF powder and then polished normally, but this is very expensive to have done by a prototyping service when I am steal tweaking the design. By expensive, I mean that a single part that is about 120mm x 15mm x 7mm in rough dimensions will cost at least $50 each. One service quoted $96 for this single part!
Thoughts on this idea?
