Threads 1 to 20 of 349
  1. Is this threaded hole perpendicular?
    Started by rbraithwaite, 09-19-2024 03:49 AM
    09-20-2024, 06:26 AM Go to last post
  2. Profile with additional tolerance?
    Started by shauntae_crouse, 06-28-2024 06:07 PM
    06-28-2024, 08:11 PM Go to last post
  3. Plug gauge size
    Started by newone, 06-14-2024 07:55 AM
    06-14-2024, 07:13 PM Go to last post
  4. BAD GD&T conversion
    Started by joel_lapointe631, 06-05-2024 12:57 PM
    06-05-2024, 03:36 PM Go to last post
    05-21-2024, 10:29 PM Go to last post
  5. Feature of size
    05-21-2024, 10:27 PM Go to last post
  6. Unequally Disposed Profile
    05-21-2024, 10:25 PM Go to last post
    05-21-2024, 10:21 PM Go to last post
  7. checking fixture question
    Started by peter_asztal, 05-16-2024 09:32 AM
    05-16-2024, 09:32 AM Go to last post
  8. Auto wheel bearing run out stack up
  9. Basic dim's interpretation
  10. Hole pattern on narrow edge datum precedence
  11. two perpendicular axes as DRF?
    datum, drf, gd&t
  12. Slot True Position
  13. Position tolerance with parallelism
  14. Profile of a line on a drawing?
  15. surprise2 Heat Treat callout
Forum Information and Options
Moderators of this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
