Threads 1 to 20 of 347
  1. Plug gauge size
    Started by newone, 06-14-2024 07:55 AM
    06-14-2024, 09:03 AM Go to last post
  2. BAD GD&T conversion
    Started by joel_lapointe631, 06-05-2024 12:57 PM
    06-05-2024, 03:36 PM Go to last post
    05-21-2024, 10:29 PM Go to last post
  3. Feature of size
    05-21-2024, 10:27 PM Go to last post
  4. Unequally Disposed Profile
    05-21-2024, 10:25 PM Go to last post
    05-21-2024, 10:21 PM Go to last post
  5. checking fixture question
    Started by peter_asztal, 05-16-2024 09:32 AM
    05-16-2024, 09:32 AM Go to last post
  6. Auto wheel bearing run out stack up
  7. Basic dim's interpretation
  8. Hole pattern on narrow edge datum precedence
  9. two perpendicular axes as DRF?
    datum, drf, gd&t
  10. Slot True Position
  11. Position tolerance with parallelism
  12. Profile of a line on a drawing?
  13. surprise2 Heat Treat callout
  14. :bash: Flatness and surface finish spec
    Started by chrishilton979, 03-20-2023 10:15 AM
    03-21-2023, 07:20 AM Go to last post
Forum Information and Options
Moderators of this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
