Related Resources:
Geometric Boundaries II GD&T Reference Book
Class V Locational Interferance Fit Tolerance Chart for Holes and Bolts per McDonald Douglas Design Guide "Machining Tolerances".
Units given in inches
Locational interference fits are used where accuracy of location is of prime importance, and for parts requiring rigidity and alignment with no special requirements for bore pressure. Such fits are not intended for parts designed to transmit frictional loads from one part to another by virtue of the tightness of fit.
Class V Locational Interference Tolerance Chart for Holes and Bolts |
Basic Diameter |
Hole Diameter |
Shaft Diameter |
Interference Maximum Minimum |
.125 |
.1240 .1248 |
.1254 .1250 |
.0014 .0002 |
.156 |
.1562 .1570 |
.1576 .1572 |
.0014 .0002 |
.188 |
.1875 .1883 |
.1889 .1885 |
.0014 .0002 |
.213 |
.2188 .2196 |
.2202 .2198 |
.0014 .0002 |
.250 |
.2500 .2508 |
.2514 .2510 |
.0014 .0002 |
.281 |
.2812 .2820 |
.2828 .2823 |
.0016 .0003 |
.312 |
.3125 .3133 |
.3141 .3136 |
.0016 .0003 |
.344 |
.3438 .3446 |
.3454 .3449 |
.0016 .0003 |
.375 |
.3750 .3758 |
.3766 .3761 |
.0016 .0003 |
.406 |
.4062 .4070 |
.4078 .4073 |
.0016 .0003 |
.438 |
.4375 .4383 |
.4391 .4386 |
.0016 .0003 |
.469 |
.4688 .4796 |
.4704 .4699 |
.0016 .0003 |
.500 |
.5000 .5008 |
.5018 .5011 |
.0016 .0003 |
.562 |
.5625 .5634 |
.5643 .5637 |
.0018 .0003 |
.625 |
.6250 .6259 |
.6268 .6262 |
.0018 .0003 |
.688 |
.6875 .6884 |
.6893 .6887 |
.0018 .0003 |
.750 |
.7500 .7509 |
.7518 .7512 |
.0018 .0003 |
.812 |
.8125 .8134 |
.8145 .8138 |
.0020 .0004 |
.875 |
.8750 .8759 |
.8770 .8763 |
.0020 .0004 |
.938 |
.9375 .9384 |
.9395 .9388 |
.0020 .0004 |
1.000 |
1.0000 1.0009 |
1.0020 1.0013 |
.0020 .0004 |
1.125 |
1.1250 1.1260 |
1.1273 1.1265 |
.0023 .0005 |
1.250 |
1.2500 1.2510 |
1.2523 1.2515 |
.0023 .0005 |
1.375 |
1.3750 1.3760 |
1.3773 1.3765 |
.0023 .0005 |
1.500 |
1.5000 1.5010 |
1.5023 1.5015 |
.0023 .0005 |
1.625 |
1.6250 1.6260 |
1.6275 1.6266 |
.0025 .0005 |
1.750 |
1.7500 1.7510 |
1.7525 1.7516 |
.0025 .0005 |
1.875 |
1.8750 1.8760 |
1.8775 1.8766 |
.0025 .0005 |
2.000 |
2.0000 2.0010 |
2.0025 2.0016 |
.0025 .0005 |
2.250 |
2.2500 2.2511 |
2.2528 2.2518 |
.0028 .0007 |
2.500 |
2.5000 2.5011 |
2.5028 2.5018 |
.0028 .0007 |
2.750 |
2.7500 2.7511 |
2.7531 2.7520 |
.0031 .0009 |
3.000 |
3.0000 3.0011 |
3.0031 3.0020 |
.0031 .0009 |
3.250 |
3.2500 3.2512 |
3.2535 3.2523 |
.0035 .0011 |
3.500 |
3.500 3.5012 |
3.5035 3.5023 |
.0035 .0011 |
3.750 |
3.7500 3.7512 |
3.7535 3.7523 |
.0035 .0011 |
4.000 |
4.0000 4.0012 |
4.0035 4.0023 |
.0035 .0011 |
Related Resources:
