Class I - Loose Fit Tolerance Chart for Holes and Bolts
Related Resources:
Class I - Loose Fit Tolerance Chart for Holes and Bolts per McDonald Douglas Design Guide "Machining Tolerances".
Units given in inches
Loose running or sliding fits / tolerances are intended for use where wide commercial tolerances may be necessary, together with an allowance, on the external member.
Basic
Diameter
Hole
Diameter
Shaft
Diameter
Clearance
Maximum
Minimum
.125 .1250
.1258
.1246
.1236
.0004
.0022
.156 .1562
.1578
.1558
.1548
.0004
.0030
.188 .1875
.1891
.1871
.1861
.0004
.0030
.213 .2188
.2204
.2184
.2174
.0004
.0030
.250 .2500
.2516
.2496
.2486
.0004
.0030
.281 .2812
.2832
.2805
.2794
.0007
.0038
.312 .3125
.3145
.3118
.3107
.0007
.0038
.344 .3438
.3458
.3431
.3420
.0007
.0038
.375 .3750
.3770
.3743
.3732
.0007
.0038
.406 .4062
.4082
.4055
.4044
.0007
.0038
.438 .4375
.4395
.4368
.4357
.0007
.0038
.469 .4688
.4708
.4681
.4670
.0007
.0038
.500 .5000
.5020
.4993
.4982
.0007
.0038
.562 .5625
.5650
.5615
.5603
.0010
.0047
.625 .6250
.6275
.6240
.6228
.0010
.0047
.688 .6875
.6900
.6865
.6853
.0010
.0047
.750 .7500
.7525
.7490
.7478
.0010
.0047
.812 .8125
.8155
.8113
.8100
.0012
.0055
.875 .8750
.8780
.8738
.8725
.0012
.0055
.938 .9375
.9405
.9363
.9350
.0012
.0055
1.000 1.0000
1.0030
.9988
.9975
.0012
.0055
1.125 1.1250
1.1285
1.1235
1.1218
.0015
.0067
1.250 1.2500
1.2535
1.2485
1.2468
.0015
.0067
1.375 1.3750
1.3785
1.3735
1.3718
.0015
.0067
1.500 1.5000
1.5036
1.4985
1.4968
.0015
.0068
Related Resources:
