Engineering Properties Structural Lumber Douglas-Fir-Larch, Hem-Fir, Spruce-Pine-Fir
Civil Engineering and Design
Engineering Material Properties
Engineering Properties of Visually Graded Structural Lumber Douglas-Fir-Larch, Hem-Fir, Spruce-Pine-Fir.
Stress-graded structural lumber is produced under two systems: visual grading and machine grading. Visual structural grading is the oldest stress grading system. It is based on the premise that the mechanical properties of lumber differ from those of clear wood because many growth characteristics of lumber affect its properties; these characteristics can be seen and judged by eye (ASTM D245). The principal growth features affecting lumber properties are the size and location of knots, sloping grain, and density.
Grading rules for lumber nominally 2 x 4 in (standard 38 x 89 mm) thick (dimension lumber) are published by grading agencies (listing and addresses are given in ‘‘National Design Specification,’’ American Forest & Paper Association, 1992 and later). For most species, allowable properties are based on test results from full-size specimens graded by agency rules, sampled according to ASTM D2915, and tested according to ASTM D4761. Procedures for deriving allowable properties from these tests are given in ASTM D1990. Allowable properties for visually graded hardwoods and a few softwoods are derived from clear-wood data following principles given in ASTM D2555. Derivation of the allowable strength properties accounts for within-species variability by starting with a non parametric estimate of the 5th percentile of the data. Thus, 95 of 100 pieces would be expected to be stronger than the the assigned property. The allowable strength properties are based on an assumed normal duration of load of 10 years.
Lumber Visually Graded Dimension, Engineering Design Properties - Engineering design values are for normal load duration and dry service conditions
Design values, (lb/in2) |
Species and commercial grade |
Size classification, in |
Bending Fb |
Tension parallel to grain Ft |
Shear parallel to grain Fv |
Compression perpendicular to grain Fc⊥ |
Compression parallel to grain Fc |
Modulus of elasticity E |
Grading rules agency |
Douglas-Fir-Larch |
Select structural |
1,000 |
1,000 |
95 |
625 |
1,700 |
1,900,000 |
WCLIB WWPA |
No. 1 and better |
2 – 4 thick |
1,150 |
775 |
95 |
625 |
1,500 |
1,800,000 |
No. 1 |
1,000 |
675 |
95 |
625 |
1,450 |
1,700,000 |
No. 2 |
2 and wider |
875 |
575 |
95 |
625 |
1,300 |
1,600,000 |
No. 3 |
500 |
325 |
95 |
625 |
750 |
1,400,000 |
Stud |
675 |
450 |
95 |
625 |
825 |
1,400,000 |
Construction |
2 – 4 thick |
1,000 |
650 |
95 |
625 |
1,600 |
1,500,000 |
Standard |
550 |
375 |
95 |
625 |
1,350 |
1,400,000 |
Utility |
2–4 wide |
275 |
175 |
95 |
625 |
875 |
1,300,000 |
Hem-Fir |
Select structural |
1,400 |
900 |
75 |
405 |
1,500 |
1,600,000 |
WCLIB WWPA |
No. 1 and better |
2 – 4 thick |
1,050 |
700 |
75 |
405 |
1,350 |
1,500,000 |
No. 1 |
950 |
600 |
75 |
405 |
1,300 |
1,500,000 |
No. 2 |
2 and wider |
850 |
500 |
75 |
405 |
1,250 |
1,300,000 |
No. 3 |
500 |
300 |
75 |
405 |
725 |
1,200,000 |
Stud |
675 |
400 |
75 |
405 |
800 |
1,200,000 |
Construction |
2 – 4 thick |
975 |
575 |
75 |
405 |
1,500 |
1,300,000 |
Standard |
550 |
325 |
75 |
405 |
1,300 |
1,200,000 |
Utility |
2–4 wide |
250 |
150 |
75 |
405 |
850 |
1,100,000 |
Spruce-Pine-Fir |
Select structural |
1,250 |
675 |
70 |
425 |
1,400 |
1,500,000 |
NLGA |
No. 1–No. 2 |
2 – 4 thick |
875 |
425 |
70 |
425 |
110 |
1,400,000 |
No. 3 |
2 and wider |
500 |
250 |
70 |
425 |
625 |
1,200,000 |
Stud |
675 |
325 |
70 |
425 |
675 |
1,200,000 |
Construction |
2 – 4 thick |
975 |
475 |
70 |
425 |
1,350 |
1,300,000 |
Standard |
550 |
275 |
70 |
425 |
1,100 |
1,200,000 |
Utility |
2–4 wide |
250 |
125 |
70 |
425 |
725 |
1,100,000 |
Reference: Reproduced with permission of the American Forest and Paper Association
Disclaimer
| Feedback | Advertising
| Contact
