Wide Flange Beam with Unequal Flanges per. Roarks Formulas for Stress and Strain Equations and Calculator
Wide Flange Beam with Unequal Flanges Section with Concentrated Intermediate Torque applied Deflection and Stress Equations and Calculator #7 of 1a Loading.
Formulas for the elastic deformations of uniform thin-walled open members under torsional loading.
Per. Roarks Formulas for Stress and Strain - Formulas for torsional properties and stresses in thin-walled open cross sections, Table 10.2.
Section Dimensional Definitions Figure 1
Loading Configuration (Section Shown May not Match Section given in Figure 1)
Left end free to twist and warp, right end free to warp but not twist.
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam
Figure 2
Loading Declarations Image (Section Shown May not Match Section given in Figure 1)
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam Orientation Declarations Image
Figure 3
Preview: Wide Flange With Unequal Flanges Thin Wall Stress and Torsional properties #7 calculator
Wide Flange Section Properties Constants Formulas See: Figure 1
throughout the thickness at points A and B if t2b22 > t1b12 |
throughout the thickness at points C and D if
t2b22 < t1b12 |
Shear stress due to warping rigidity |
throughout the thickness at a point |
throughout the thickness at a point midway
between C and D if t2b2 < t1b1 |
at the surface everywhere |
Shear stress due to torsional rigidity
Left end free to twist and warp, right end free to warp but not twist Formulas:
Point 0 indicates the shear center se "Concentrated intermediate torque of Channel Beam Orientation Declarations image ";
G = modulus of rigidity (shear modulus) of the material (lbs/in2, m2);
θ', θ'', θ''', = are the successive derivatives of y with respect to the distance x;
A, B, C, D, E, F, e, h, b1= Dimensional data Figure 1 (in, m).
Unit step function defined by use of 〈 〉
〈 x - θ 〉0
if x < a, 〈 x - a 〉n =0;
if x > a, ( x - a) n ;
The function sinh β
β = ( KG/CwE)1/2
Roarks Formulas for Stress and Strain, 7th Edition, Table 10.2 and 10.3 Formulas for torsional properties and stresses in thin-walled open cross sections.
