Wet and Dry Steam Mass and Volume Fraction Calculator
Heat Transfer Engineering
Thermodynamics
Steam is a gaseous form of water-air vapor and there are two forms, wet steam and dry steam. Steam is when all of the steam is in a vapor form and is considered wet when there are tiny liquir particles suspended in the mass of the dry vapor. WAter can be converted to steam by the the application of heat energy however not all water may be converted into dry steam - vs a percentage of wet steam is present.
The dryness fraction of wet steam is utilized to quantify the amount of water dropletts within the steam.
The Quality x of steam condensate can be defined as:
x = mVAP / ( mLIQ + mVAP )
where
mVAP = mass of saturated vapor to condensate
mLIQ = mass of saturated liquid to condensate
The Volume Fraction Vc of the vapor in the condensate is expressed as:
Vc = VVAP / ( VLIQ + VVAP )
where
VVAP = volume of saturated vapor in condensate
VLIQ = volume of saturated liquid in condensate
Source
  • Heat Transfer, A Practical Approach Yunus A. Cengel
