Viscous Torque and Power on Rotating Shafts Equations and Calculator
Rotating Shaft in Bearing
Preview: Viscous Torque and Power on Rotating Shafts Calculator (Membership Required: Premium).
Shear stress, τ = µ (du/dy) = µ (u/y), as linearity is assumed
u = π DN/60, y = h, clearance in m
τ = µ (πDN/60h), Tangential force = τ × A, A = πDL
Torque, T = tangential force × D/2 =µ (πDN/60h) (πDL) (D/2)
substituting T = µ π2NLD3/ 120 h
If radius is used, T = µπ2NLR3/15 h
As power, P = 2πNT/60,
P = µπ3N2LR3/450 h
Clearance h is also the oil film thickness in bearings.
End effects are neglected. Linear velocity variation is assumed.
Axial location is assumed.
L = Length (m)
R = Radius (m)
D = Diameter (m)
h = Clearance (m)
N = Revolutions per minute (rpm)
µ = Viscosity of fluid (Ns/m2 or Pas).
The torque will be obtained in Nm and the power calculated will be in W.
